Hi Tom
Hope you are doing well.
I have a few questions about programming the homing sequence for a master/slave axis on my cnc router with a gantry.
First off, my x axis is driven by two servos, one on each side and one slaved to the other.
The slave axis's count is the reverse sign of the master and I have set the slave gain to -1 on account of this. Is this the proper manner to handle this or is there a better way to do this. (ie. possibly by setting input and output gain to -1) and if
so what would I also need to change in kmotioncnc. I do not believe I can change the sign of the gain on the drive.
I looked at your example file "homeslaved.c" in the c programs folder of the kmotion432 folder. I notice that your distances and speeds are not the reverse sign for the 2nd axis. How do you accomplish this? Do you set input and output gain at -1? If so, do I need to change anything in kmotioncnc as well?
Also, when using commands such as moveatvel(axis, distance, speed). If my axis are reversed sign and I wish both to travel the same distance and at the same speed do I need to reverse the sign on the slave for both speed and distance?
for example, to move both I would issued the following commands:
MoveAtVel(X0_Axis, X0_Dist, speed)
MoveAtVel(X3_Axis, -X0_Dist,-speed)
Or do I simply need to reverse the sign on the X0_Dist variable and not include a sign on the speed as follows:
MoveAtVel(X3_Axis, -X0_Dist, speed)
Thank you
Darren
